raysablade
i was going to buy a Qutest today, i'm glad i read this before i did. Its saved me months of angnt and good holday.
Maybe if the bass player used a genuine Fender rather than a Squire copy, the same could be achieved.
Not trying to be funny, but an interesting point
I assume you are talking about timing, but one of those bass's will sound better than the other.
Melco works just fine with MScaler; I tried it in my system, into my Chord Dave. Very good, but then Dave's pretty spiffing on his own.I checked and my Hugo 2 does indeed take the dual connection, so should work fine. Melco recognises Chord DACs but since the m scaler would sit after the Melco, it raises the question about compatibility. I shall ask Rob Watts or a Chord person next week
Indeed Tony. I have been enjoying Audiostore Prestige 3 out via USB to M Scaler + DAVE.Melco works just fine with MScaler; I tried it in my system, into my Chord Dave. Very good, but then Dave's pretty spiffing on his own.
Of course not, he'll be much happier if you buy an M-Scaler...I upsample Roon to 705.6 kHz before presenting the signal to my tt2 & swear it sounds better. I don't think Rob Watts would approve
I may be wrong, but I don't think anything as tawdry as commerce matters to him at this stage of his career. My impression from his writings is that he believes software cannot replicate what the HMS does. I don't know how a hammer works, so am hopelessly unqualified to argue the technical toss. However, I can't remember there being such a buzz around a bit of kit for a long time, so I will get one on loan.
I only so far looked at the first few minutes. I will look later at the rest but for now I don't get the 4μs transients argument.… Just watched Rob Watts talking about it and for fiscal reasons I wish I hadn’t
How does the M-Scaler work? Is not FPGA using on-board software?
What if software doesn't replicate it's performance but produces more accurate reproduction?
Perhaps it does. However, I recently listened to a Chord M Scaler + DAVE fed by an Innuos Statement server. Software was Roon.
With the M Scaler doing its stuff, the sound quality was superb. Bypassing the M Scaler but upscaling/upsampling (I can never remember the difference) using Roon software on the Innuos server resulted in a relatively flat, lifeless sound.
Best regards, FT
Thanks tuga. Possibly, I don't know. To be honest, I don't really mind.It may or may not be the case here, but sometimes these perceived qualities (exciting, lively) are the result of colourations or distortion.
Some types of distortion sound nice to some people.
Isn't "upscaling" a marketing term?
I'm trying HQPlayer with Qutest at 768k. The sound is much improved along the lines of what people say about M Scaler.
Which filter are you using?
The -xtr filter is supposed to be an improved Chord filter.
I prefer the -ext2.
A couple of Jussi's post:
I created it (the -xtr) for people who like Chord Dave -style filters. It is about 5 times longer than poly-sinc and thus about 5x heavier.
Offered in linear- and minimum-phase variants.
Stop-band attenuation exceeds needs of 40-bit PCM, being over -240 dB.
Normal poly-sinc filters are created to reach excess of 32-bit PCM resolution (> -192 dB) stop-band attenuation.
Since high-rate modulators can reach peak SNR higher than 32-bit PCM resolution at audio band frequencies, I thought it could be useful…
poly-sinc-short is trying to be as few taps as possible while still having high attenuation (same as poly-sinc) and not too slow roll-off.
At the moment poly-sinc is between the -short and -xtr, but closer to -short.
I've thought about poly-sinc-long, which would be otherwise same, but longer/steeper than regular poly-sinc.
-xtr is not called -long because it changes some other parameters too, like stop-band attenuation.
The new poly-sinc-ext2 is closer to -xtr but a bit shorter, while having otherwise completely different design.
Tuga, Is HQ Player a complete package for playing files like JRiver, Foobar2000 etc? If it is, is it easy to use? (I can’t even use Foobar)
Ooh! Something else to mess about with... Tuga please do share more...
Is HQ player something you can download onto a Pi or is it mac/pc only?
Intrigued...perhaps there should be a separate thread on this?
