rockingdoc
So, without warning, my Hugo went from working normally to not working. Flashed a few different colours on switch on, but no linking to source and no audio output.
Guessing it could be the batteries, took the back off and I did a Google search on the part number, to no avail. Searching the RS site for type and specs revealed an identical looking battery, but with different part number. Took a punt and ordered.
Soldered the replacement batteries to the board, which was a little fiddly as the terminals are so close together and I was keen to avoid a short. Could have left the old leads in place, but they were looking surpringly ragged at the pcb joins, and I thought I could do better.
Plugged in and all is fine. So that’s about a hundred quid saved for five minutes work.
