Hi All
On Sunday, the Chord Hugo in my main system died. Obviously a bit disappointing. I have temporarily replaced it with a Hugo TT that I've had for a while that was seeing service in another system. I never enjoyed the TT in my main system as much as the non-TT version.
Anyway, I took the dead Hugo apart with the view to changing the batteries. However, when I opened it up it looks like the batteries are different from all the pictures I've seen previously. See pic below:
There is one picture on the interwebs of a Hugo 2 with blue batteries but no designation on them.
So my question is do you think these are newer Chord batteries (maybe changed by them) or just ones someone has found that fit and put them in? I bought it used so anything could have been done before I got hold of it.
If not Chord then I'm in a dilemma. Do I go with the normal replacement batteries or try to find ones like these again given I preferred this Hugo to a TT? Bear in mind that as far as I know, the circuit board is the same for both and the difference is in the psu/batteries (I'm not using the USB which is also different).
Any thoughts appreciated (except that all dacs sound the same )
cheers
Dave
cheers
Dave
