My CDi has slowly started to have trouble reading disks (I either get an error, or it just sits chugging away) although once its actually started playing it tends to play fine. This is not the same problem as when the disk slips in the mechanism because the disk is too thin.
Having said that, occassionally I also get what can best be described as a fluttering noise in the bass, but this is intermittent and this happens every couple of weeks.
I bought a new CDM9/44 transport but the motor connector was different (I had a ribbon, the replacement came with a 2wire/white plastic lug), so I just changed the laser part over suspecting that might be at fault, and bought a new Puk. (My CDi is the later one with the puck not the top hat)
Things are still not right though. Any suggestions?
TIA Jon
TIA Jon
