The rega arm will be fitted in its correct geometric position as the project will include works to the plinth.
I must admit I'm interested in people's views specifically involving Ortofon cartridges as this is an itch I'd like to scratch!
Also any comments on Goldring 1042 which I've rad good things about, albeit not specifically relating to the Rega RB303?
Correct position,,,great then, I'd expect it to become a really stunning deck in result
Rgdg Orthopfon I have no xp myself, so cannot comment, heard lots of good opinions on that, though.
The Rega arms, anyone the RB303 will be no exception there and the Goldring 1022 and especially Goldring 1042 were dream matches on Rega decks.
I heard my good friends Rega 3 with this arm/ cart combination when I was running a Zyx Yatra Silver on Ekos on my LP12 at that time, and while the Rega did not match the fine resolution of the Zyx for sure, it still was asking my big respect how great it sounded..how competent and how much resolution it delivered that every time I had the impression I was hearing MC, not an MM cart.
Maybe someone has XP with a direct comparison Rega G1042 to Ortofon, as I don't.
I will get a G1042 for my second deck when the Zyx has died.
The Adikt mm from Linn is said to be a G1022, and I consider the 1042 quite a bit better.
I think the lower range of MCs makes not much sense from a G1042, to really better it, it takes quite a bit more money and a decent MC.
One exception might be the Denon 301, it was said before it does not match the Rega arm due to resonance frequency, but the 1 time I heard it on a DPS it was mindblasting to me (by then), as an experience I won't forget.
Might be worth a listen, I saw Fox has the 301 in a Rega in his own built of rainbow machine pony deck & I have a suspicion his creation sounds (perhaps) better than most imagine..
