Chris
I am in the throes of testing various values in my Y splitter cables to find the capacitance value that sounds best with my MM cartridge in my set up. I made the cables up using tiny ceramic caps inside three sets of load plugs (80, 180 and 390 pF respectively) but I had no real idea of the interval between values to go on - my cartridge manufacturer reckons a total cap value of 400pF but that includes arm cable, phono input and the splitter so we’ll see. As expected I think I have discounted the 390 ones and this week I am trying the 180 which sound much more like it. Anyway I am writing to see if ceramics are a good choice or if, when I go for the definitive caps to fit inside my phono stage, should I opt for other types.
By the way, Is my EE mate way out of order when he says I can forget the capacitance of arm cable and splitter cable because values are given per kilometre length and a few centimetres are not going to make any difference.
P.s. In my system, there is definitely an easily notable to the ear difference between differing cap values, at least between 180 and 390 pF. Like the difference between crap and good.
