nitrous
Hi all, to cut a long story short my elderly parent’s amp has died. I would like to fix it because trying to get something new they can learn to use will be tricky. The amp has the phono stage fitted, which has a Rega 2 attached.
The symptoms are when switching on, with volume down amp lights up, outside/front panel LED and both red power amp LEDs inside indicating everything is powered. As soon as volume is moved even ever so slightly a huge ‘rustling’ distortion sounds almost at full volume (drivers leap about!) is all that can be heard. There is no sign of the signal from (in this case) DAB tuner or turntable, just the noise.
I was hoping to find leaking caps when I opened up case, but nothing visible.
Any ideas welcome, changing volume pot or caps should be within my capacity.....
Cheers.
Cheers.
