Calling thorens 150 owners
Discussion in 'd.i.y.' started by john & Jake, Mar 12, 2023.
  1. john & Jake
    john & Jake Jake was smarter than me
    Hi, could anyone please supply the measurement between the platter centre spindle and the centre of the motor adjustment screw.
    I'm making a turntable based on 150 parts.
    Thanks in advance.
  2. Toaster
    Toaster pfm Member
    I'm away at the moment, but if no one else has responded by this time next week, I can do that then.
  3. john & Jake
    Thanks Toaster, thats brilliant.
  4. matt j
    matt j pfm Member
    Same here, make sure to put up a thread in here would love to see it!
  5. chartz
    chartz If it’s broke fix it!
    There is exactly 120 mm between motor pulley centre and platter spindle centre. That’s what you really need. Also, do get a genuine Thorens belt. The best would be a clutch pulley if you can get one: the belt will last for ages with it, like 15 years, just a couple of years without it – unless you help the platter at startup. And a Valhalla is a good idea too.
    Happy DIYing.
  6. john & Jake
    Thats fantastic, thanks chartz. You are right thats a better measuring point.
    I can now get on with the paper template.
    I'll post my progress.
  7. Craig B
    Craig B Re:trophile
    Not that you are necessarily attempting to build an actual TD150 from TD150 parts, however, some of the dimensions from the original Thorens mounting template may come in handy (sorry, its the only image I have).
  8. john & Jake
    Hi thanks craig.
    I am attempting a more skeletal plinth something along the lines of the Rega P8.
  9. Craig B
    Craig B Re:trophile
    That sounds interesting, John. Looking forward to seeing what you come up with.
