James
Lord of the Erg\o/s
A resistor change alone won't fix the baffle step loss. If the crossover is accessible, it'll need to be changed for free-space operation. How are you finding them as is?James,
I've acquired a pair or your Ergo E-IX, it has the close to the wall crossover. I'll be using them in free space close monitor position. Would the resistor across the tweeter mod work in this instance or am I better off changing the crossover components?
The baffle has been glued, is there a smart way of fitting leather covers as per your original examples? Woodworking isn't one of my skills unfortunately.
As for retro-fitting leather, it'll be nearly impossible for the following reasons:
(1) The driver cutouts needs to be 1-1.5mm larger in radii to accommodate tucking the leather under their flanges.
(2) The baffle needs to be around 3mm smaller to tuck in the leather at the edges of the baffle.
(3) The baffle needs to be removed to make these changes.
Simply sticking a piece of leather on the surface will look rather untidy, I'm afraid.
Your other option is to order a free-standing XO and cabinet kit from Stefan, and reuse the drivers. That way, you can have both versions pending a driver swap.
