ultrawomble
Sith Lord
Oh OK - I honestly didn't know where you were going with that line of enquiry. Perception is a function of the mind. Blind medical trials are effective because they separate the psychological element from the autonomous biological functions of the subject so we can tell whether a treatment really 'works' - ie, acts effectively on the subject's somatic biochemistry.
And as I have already pointed out to you, psychotropics work by altering the biochemistry. Hence the 'psychology' is dependent on the biology - you can't separate them. The test removes the expectation bias, not the effect.
However you can't remove the psychological element from the listening process: you could argue that it's 'only' a neuro-physiological process but that would be a little specious. The bottom line is that if the test method tampers with the mental state of the listener, it will inevitably distort the outcome. Is that clearer?
It's very interesting that Sean Olive has used blind trials to demonstrate the superiority of CD over MP3, and well engineered 'speakers over those less well engineered - linky. By your logic, I guess we should disregard those observations?
