JimmyB
What are the thoughts, pros and cons, around using either a single large transformer e.g. 500VA 30-0-30 and running both channels from a separate 30V output on this as opposed to 'full' mono two smaller single transformers e.g. 200VA 15-0-15 run as single 30V rail?
Both would provide enough current headroom so is there an advantage? No regulators before any amp stages is the plan, so essentially a NAP180 type build.
