I read that Chord Epic Super Twin(bi-wire) sounds closest to the Naca5. However a 5m length of this cable is significantly costlier than the Naca5. Are there any other alternatives? It is unfortunate Naim do not produce Naca5 in bi-wire versions.
Anyone got a positive result replacing the stock links on the speaker terminals to small snips of Naca5? Is this worth a shot, or I'm better off getting some bi-wire cables(obviously not a Naca5 anymore)? Naim amps in use.
Thanks in advance.
Thanks in advance.
