Best way to cut an IEC inlet shaped hole in a Popely case?
Discussion in 'd.i.y.' started by colasblue, Sep 27, 2012.
  1. colasblue
    colasblue pfm Member
    Hi Guys
    I've got a few of these and can feel a Hicap replacement project coming on.
    Got all the bits to build th first one and the only thing I haven't attempted before is to cut out a big rectangular hole for a fused switched IEC inlet.
    I'm considering doing it by the cheating method of cutting out a c shaped hole at one edge of the case, which is probably a whole lot easier but a bit of a bodge. I could do that by just making two hacksaw cuts and work hardening out the middle bit with a pair of grips.
    Is there an easy way to do it properly and accurately without any special tools? I know I could drill out lots of holes and join them up and file the edges square but that's a bit of a fag.
  2. d.rushy
    d.rushy Active Member
    Use a hole saw,drill a hole with it up to the edges of the rectangle marked out,should be able to do 2 holes,then file the corners flat. Job done.
  3. sq225917
    Masking tape, drilled corners, 38mm Dremel cutting wheel and a small file to even it off.
  4. Bethelcat
    Bethelcat Active Member
    Hole saw is a good approach. Most useful tool for such jobs would be a Dremel...
  5. Pete MB&D
    Hi,
    Chain drilling is the best way, a series of 3mm or so holes close together near the outline cut the webs with cutters or fille with a needle file, then file square.
    Pete
  6. sam_cat
    sam_cat C'est Crounchifique!
    I usually mask, mark the shape I want, drill in the middle then use my step drill to enlarge.. Then jigsaw with metal cutting blade then file to finish. Neat holes. :)
  7. YNWOAN
    YNWOAN 100% Analogue
    I've done this exact task task a number of times to these very cases. I've chain drilled them - which works OK but takes ages - I've also use a Dremel disc cutter and this works well. However, the easiest was to use a coping saw (yes, one intended for wood) - cuts aluminium very well indeed (you have to drill a pilot hole of course). A step drill works well for round holes. Neatly mask the back out first with masking tape and neatly draw the shape you want in either biro or fine liner (pencil isn't so easy to see and an rub off). You will need to hold it in a vice (with soft jaws).
  8. colasblue
    Yes coping saw was another thought, but having recently had a lot of trouble making a coachbolt head size square hole in a stainless steel saucepan, for which I resorted to that very method I was a bit unconvinced by it, but if you say it works I'll give it a go.
  9. YNWOAN
    Cutting stainless steel and cutting aluminium are two very different things (the blade is too coarse for SS). Trust me, a coping saw works very well on Andrew's cases - I did one only a few weeks ago - took five minutes and after a light file the IEC socket was a perfect fit.
    For your saucepan I would have drilled a hole and then used a flat needle file to square it off.
  10. Suffolk Tony
    Suffolk Tony Aim low, achieve your goals, avoid disappointment.
    Yep, coping saw is the best method I've tried. Just take your time, coping saw blades are inclined to wander.
  11. Mullardman
    Mullardman Moderately extreme...
    The classic metal working way to do this would be to use a jeweler's saw. I have one somewhere. Similar to a coping saw but with finer control.
    Blades of extreme thinness can be had and can change direction easily, unlike hacksaw/coping saw blades.
    That said, they are usually used on non ferrous metals, so I don't know how they'd cope with steel, especially stainless.
    http://www.amazon.co.uk/s/?ie=UTF8&...vpone=&hvptwo=&hvqmt=b&ref=pd_sl_8gx3y2qab3_b
    Mull
  12. YNWOAN
    Yes, I agree, I have also used a piercing saw; but in this case, the case is made of aluminium and easy to cut with a standard coping saw.
  13. Mullardman
    OK.
    May I also re-introduce an old method which I suspect is rarely used these days?
    A good, sharp cold chisel.
    So long as the work can be fully supported on an anvil of some sort, intelligent use of a chisel can make quick work of most things up to mild steel.
    I would drill out corners first and finish with a file.
    Mull
  14. Suffolk Tony
    Agreed, a really sharp chisel's a good way too - certainly the fastest.
  15. YNWOAN
    Little wonder...
  16. david ellwood
  17. Jo Sharp
    Jo Sharp Pulls on doors marked push
    Or a very carefully crafted shaped charge.....
    "You were only supposed to blow a bloody IEC hole"
  18. 337alant
    337alant Negatively Biased
    during may apprenticeship in the 70s A cold steel chisel is the way I was taught in sheet metal work, you had to go into the Blacksmiths shop first though and forge you own chisel out of bar stock followed by quench and temper in whale oil. It works but you do need a really solid piece of steel underneath it and a nice sharp chisel or you'll end up distorting the back plate.
    My own preference is to drill the 4 corners and put a bigger hole in the middle, use a jig saw with a sheet metal cutting blade between them and then finish with a file.
    A high speed air saw is better than a jig saw as well if you have one ;)http://www.harborfreight.com/high-speed-metal-saw-91753.html
    http://www.amazon.com/dp/B0013WEAO6/?tag=pinkfishmedia-20
    Alan
  19. chiily
    chiily PFM Special Builder
    Not an IEC in a case, but a door in a wall; my builder must be on the same wavelength..
  20. sam_cat
    He forgot to drill a door handle....
    Get the drill out and add a door handle for him... :p
