My old Peugeot, bought in around 1995, and languishing under an occasional cover ever since. It is still covered with road grime, the front tyre doesn't appear to be perished, just filthy. The wheels seem OK,but I'm a little concerned about what to use to clean the hub up.
Chain? no problem, assuming degreasing agents haven't changed much.I'll take it off the bike, if only to check the rust is only surface rust. I seem to remember there was a school of thought that sad you shouldn't use one of those chain link removing tools, but why I'm a touch unclear.
Anyway, any advice? Most of the dire on the frame should come off with a soapy rag, it's the bits that turn/contain ball bearings/stop the thing that concern me.
Anyway, wish me luck. The bike served me well even if the purple/silver colours were bought to keep the thieves away.
