raysablade
A small project for this coming year is to have a constant Radio 3 stream available on input 3 of my amp.
I have Raspberry Pi with a DAC hat set up for this purpose and just need to decide on a stream to load into Volumio.
All of the ones I have tried are reported as 128kbs by Volumio. Is that just a quirk of the software or a limit? If it is a limit, are there any other easy to set up Pi packages that would do a better job?
I simply want to set the pi to play constantly and select Radio three in an entirely mechanical turn of a knob way. I know this sounds a little daft but it pleases me.
As an aside I’m planning to use a high capacity battery power pack as a uninterrupted power supply trickle charging it from the mains. Is there any risk in that, I’m only doing it because I know uninvited power downs upset Volumio.
PS: I know I can use an FM tuner for the same job but I’d need to install an aerial and buy a tuner
