No, it is not a VM95.
I bought the entry level one to get a TT going and it punches way above it's weight, excellent vfm. Recently bought the ML as linked above, it's over budget but if you can add the thirty quid it's what I'd buy otherwise the Goldring. Wasn't that taken with the 2M Red.If you are choosing without a demo, then the VM-95 could be the safest bet. Where a different stylus can be interchanged - with some people preferring the Conical profile. Later it is possible to change/upgrade to a Shibata or ML profile.
Andrew
I keep reading that the mp-110 is the one to get but is there anything else worth looking at?
