Bang and Olufsen Please Help Identify
Discussion in 'audio' started by Peter McDermott, Oct 24, 2021.
  1. Peter McDermott
    Peter McDermott pfm Member
    Hi Everyone,
    My neighbour has decided to give me this piece of Bang and Olufsen kit, which is a music centre. It works as he played me the record you can see sitting on the turntable platter.
    I said to him that I would seek to identify the model, so am calling on the expertise of this forum.
    Some images:
    It does have a lid but the hinges are a bit unreliable so he's taken off for the purpose of the photograph.
    Hope you can help.
    Peter
  2. chartz
    chartz If it’s broke fix it!
    Jono_13 and Beobloke like this.
  3. Peter McDermott
  4. Beobloke
    Beobloke pfm Member
    Chartz is spot on.
    And what a nice neighbour!
  5. Peter McDermott
    Thanks Beobloke. He is, no doubt about it
  6. Jono_13
    Jono_13 Duffer
  7. Peter McDermott
    Jono_13 likes this.
  8. Jono_13
    Jono_13 Duffer
    Any labels on the back?
  9. Peter McDermott
    Not sure will have a look, though still at his house so could be a few days.
    Jono_13 likes this.
  10. wow&flutter
    wow&flutter pfm Member
    Nice neighbour, for free you’ve got to grab it. Be aware the required stylus/cartridge is an mmc3000 I believe and originals can be very pricey. Not sure if anyone is offering an alternative or refurbishing so just be careful:).
    As for the speakers there should be a small silver label on the back with the model and serial number on it. If it’s come off just remove the grill and they can be identified by a photograph. It’s worth pulling the grills anyway as some of the earlier bass drivers had rubber surrounds and others had foam surrounds which may well have deteriorated by now but replacements should be available
    Jono_13 and Peter McDermott like this.
  11. Beobloke
    Beobloke pfm Member
    For cartridge refurbishments, you have two options that I know of:
    - Audio Origin - https://audio-origin.co.uk/cartridge-retipping.html
    - Franz-Josef Schulte - https://www.tonabnehmerservice.de/en/Retipping-of-MM-and-MC-cartridges/
    And there is a third in the form of Sound Smith I suppose.
    wow&flutter likes this.
  12. PerF
    PerF Scandinavian Member
    B&O did some really nice looking kit back then.
    I've heard they are difficult to refurb if needed.
  13. chartz
    No they aren’t I can tell you that!
    That is a myth.
    They need some care but the service manuals are gems.
    Plus they don’t use unobtainium parts. I often use what’s in my drawers.
    Belts, idlers are all available too. As well as used parts should you need a motor for instance.
  14. Beobloke
    Beobloke pfm Member
    No, no you’re quite wrong. Very difficult to service, made of unobtanium and cantfindium, sealed for life gearboxes and all that. They’re also full of dangerous stuff like asbestos, dynamite, mercury and acid.
    Best thing to do if you have any B&O is to send it to an authorised person for disposal. Obviously I’d be more than happy to help with this and wouldn’t even charge you…
  15. Jono_13
    Jono_13 Duffer
    Truly selfless, bravo.
  16. Peter McDermott
    Thanks Beobloke, I've called the emergency services
    Jono_13 and PerF like this.
  17. chartz
    Okay, sorry about the lies. :(
    Obviously I have never done any repairs on B&O stuff, I was just bragging.
    I’ll get me coat.
    Beobloke and Jono_13 like this.
  18. docstocker
    docstocker pfm Member
    Looks like the combined beolab 1700 tuner and beomaster amp that were available separately
    My first amp and tuner from mid 70s
  19. Rosewind
    Rosewind Lost in Translation
    The 1700 Beolab looks a bit like the Beocenter 1800 without amp and turntable.
