ToTo Man
the band not the dog
I realise part of a dying breed who still streams music from local storage, but I'll ask anyway.
When I was optimising my digital playback setup almost a decade ago, I used to frequent the ComputerAudiophile forum for advice (it's now called AudiophileStyle). There was a strong consensus that the drive on which your media is stored should NOT be connected to your computer using the same interface as your DAC, in order to avoid bottlenecks and noise being injected into the DAC. i.e. If your DAC was connected bu USB, your external hard disk should be connected by FireWire, eSATA or Ethernet.
See this thread for example:
https://audiophilestyle.com/forums/topic/14933-any-harm-using-usb-external-hdd-with-usb-dac/
I've followed this advice for almost a decade. I started off with a portable bus-powered 2TB WD MyPassport FireWire drive, then when I outgrew that I bought an OWC Mercury Elite Pro FireWire enclosure and installed a 6TB WD Blue HDD.
I'm now at a crossroads. Having filled the 6TB external drive to the brim I need more space, so I either pay over the odds for a 10TB WD Red drive and install that into the OWC enclosure, or for the same sort of money I could buy a 14TB WD Elements external USB drive. The latter of course necessitates that I connect the drive to my 2010 Mac Mini by USB instead of FireWire.
My Mac Mini has a total of 4 USB ports. I often have two DACs and a UMIK-1 microphone connected at any one time, and I can't say I've noticed any difference in the performance of the DAC I'm listening to whether or not these two other devices are connected. An external hard drive may however be another kettle of fish, as the data transfer rates involved are likely to be much higher.
Does anybody have first-hand experience of a worsening in audio performance from their USB DAC as a result of streaming music/video from an external HDD that's connected to their computer by USB instead of FireWire? Or is this a prime example of audio nervosa?
