That bloke does go on a bit.
Pretty much every bloke on YouTube could do with ‘getting to the bloody point’ a lot faster!
Talking of which, can anyone explain how these could possible work?
Need to hit 10 minutes, or they don't get the filthy lucre!
How does that work? How do you get paid?
I have no idea, I am skeptical that it does but it reminds me of something I did years ago. I needed a multi-way extension to plug all of my stuff in. The one I had was a very cheap four-gang. Just to see what would happen, I removed the fuse from the plug of the extension and soldered in a brass bar. Actually a cut-down earth pin out of another plug.
It sounded better! I don't use it for long, as it was a ridiculously unsafe thing to do, but it was interesting. I've done lots of similar things and it's quite consistent. If you improve any connection, whether it is signal or mains, you can hear it. Usually.
Talking of which, can anyone explain how these could possible work? https://www.synergisticresearch.com/fuses/orange-fuse/
