So -- this is a bit of a shot in the dark. But I recently purchased a 2nd hand M-DAC with a non-functioning volume knob. The knob can be used as a selector -- i.e., the "push" functionality works -- but it does not work when you turn it to adjust the volume or change settings. The remote works fine, so I have full functionality, except... I am unable to disable the amplifier, as you need to be able to turn the volume knob to do that.
My question is: Does anyone know whether this is a relatively easy fix? I have a local repair guy who could likely address it, but I don't want to spend a lot of money on time as I'm fine (and actually prefer) just leaving the volume set at 0 db and using my integrated to adjust the volume.
