Hi folks,
The other day I powered up my hifi and noticed no sound coming out. I looked at my Audiolab and noticed a message about 'control update' on the screen. That didn't seem right to me since it hasn't got any connectivity and so it can't check for updates. If I pressed the 'enter' knob it started a countdown, but I didn't want to proceed with this so I stopped. Pressing the 'menu' button allows the unit to continue to boot up and then work perfectly.
Bit strange, but I put it down to a one-off.
Today it happened again. This is what appears:
Again, pressing the 'Menu' button allows it to proceed as normal.
Just wondering if anyone has come across this odd issue? @JohnW ?
The only thing I can think of is there's some strange IR combination being sent by my Logitech Harmony remote system. Can this feature be invoked by certain button presses?
Thanks,
Howard.
Thanks,
Howard.
