Pulls downward and backward at almost the same angle as with AT95E, but for different reasons that are revealed once it's off.
There are raised grip bars either side, toward the back along the bottom edge of the stylus assembly. Keep it parallel to the top of the body; the intention being to 'bias' the downward pull toward the rear.
