Dowser
Learning to bodge again..
Hi All
Picked up one of these very cheaply recently - anyone have any experience of them? Fair bit of info on the net, looks foo-like at first glance
Plugs into mains socket and a spare RCA - only earth of RCA connected to Blue Dot. Something was bouncing around inside this one, so wanted to open it before plugging it in. Haha - as well as the 4 case (cheap plastic box) screws, they also glued the damned cover on - always a good sign
Hack-sawed the back two corners and prized open with a screw driver. Thing bouncing around was a bit of crystal that had come away from the copper ground plane that the RCA earth was connected to - it's covered with glued on crystal.
Active side is more of a concern - supposed to suppress RFI/EMF - this thing has not gone through any sort of safety certification process I think?! I think you can still buy one of these for $850! Hopefully put together a little better than this
Any electronic engineers want to guess what this is doing? Clearly doesn't give a shit whether powered by 120 or 240 volts, LOL
So, am I going to be reckless enough to plug this into my system? You bet I am - stay tuned
Richard
Richard
