He's likely trying to pull the stylus knob forward. He'll need to pull down and slightly backward. Best to remove the headshell first, assuming it isn't a fixed headshell Basik Plus model.Thanks. Oh and in the interim he wants to change the stylus but cant get it out, says it's 'too stiff'. Any ideas?
I’d just order the 95 now it’ll be here Mon/Tues and ditch the K9. If he is having hassles removing the stylus he should remove the K9 so he doesn’t bugger the arm bearings.Thanks. Oh and in the interim he wants to change the stylus but cant get it out, says it's 'too stiff'. Any ideas?
Audio Technica..
Just had a look on eBay - seriously how much? I gave mine away rather than buy a stylus for it years back and keep it as a spare, should’ve kept it.Yip. An AT moving magnet cart will suit the deck perfectly.
Note that while the current VM styluses fit the K9, the new carts are better than the K9 with a new stylus. I'd buy a new VM range cart and sell the K9 on eBay. Linn sheeps still pay more than is sensible for them and it would be remiss not to take advantage of that.
Problem is these idiots are pushing up the prices of old Linn turntables and arms as well which is very annoying.
