Audio_Therapy
Trade: Audio Therapy
We have for sale an Arcam AVR850 AV Receiver
This was my own personal receiver and was bought new in April 2016, selling due to house move.
RRP was £4500, asking £1800 including UK P&P
Link
It is in very good condition overall and in perfect working order. There is small mark on the front panel, that you can make out on a couple of the image, I never even noticed it until it came out of the rack, nothing serious.
It is supplied in original packaging (double boxed) and includes the instruction manual, UK power cable and remote control.
Also included is an XTZ Microphone ‘Pro’ Kit to aid with the Dirac Room Set up – this Microphone kit was of much greater quality than the one that originally came with the AVR850 and cost me £120 from memory. This Microphone kit does not connect to the AVR850 directly, it connect via USB to a laptop which runs the Dirac SW
This was sent to Arcam in June 2018 for a warranty repair, some capacitors and the front panel display were renewed and it hasn’t skipped a beat since then. No Arcam warranty remains, it came with 5 years from new.
The FW in this unit is 7.14 as you can see in one of the pictures.
Specification
Continuous power output, per channel, 8Ω/4Ω (AVR850)
2 channels driven, 20Hz – 20kHz, <0.02% THD – 120W/200W
2 channels driven, 1kHz, 0.2% THD – 130W/210W
7 channels driven, 1kHz, 0.2% THD – 100W/180W
Residual noise & hum (A-wtd) – <0.15mV
Audio Performance (Stereo line inputs)
Signal/noise ratio (A-wtd, stereo direct) – 110dB
Frequency response – 20Hz—20kHz ± 0.1dB
Video Inputs
HDMI – x7 (6 x HDMI2.0a, HDCP2.2, 1 x MHL compatible)
Video Outputs
HDMI – Z1 x2 (out1 ARC, HDMI2.0a, HDCP2.2, out2 HDMI2.0a, HDCP2.2), Z2 x1 (HDMI2.0a, HDCP2.2)
Audio Inputs
HDMI – x7, Coax SPDIF – x4, Toslink – x2, RCA Phono – x6,
3.5mm aux, USB input, Ethernet Client, Internet Radio, ARC (from display)
Audio Outputs
7.1.4 Pre-amp output – 12x RCA Phono
Zone 2 output – RCA Phono
Radio Tuner
FM / DAB / DAB+ (in appropriate markets)
Supported Surround Modes Include
Dolby Atmos, Dolby Surround
DTS:X, DTS-HD Master Audio, DTS-ES 6.1 Discrete, DTS-ES 6.1 Matrix, DTS 5.1, DTS Neural:X, DTS Virtual:X, IMAX Enhanced
General
12V Trigger x2
IR in x2
6V rSeries PSU x1
Power consumption (max) – 1.5kW (approx. 5200 BTU/hour)
Power consumption (standby) – <0.5W
Dimensions & Weights (AVR850)
W x D (inc. speaker terminals) x H (inc. feet) – 433 x 425 x 171mm
Weight (net) – 16.7kg
Weight (packed) – 20.0kg
EAN/UPC code (AV850)
5 060133 602521
[url=https://flic.kr/p/2nbCVf5][/url]
Link
Specification
Video Inputs
Video Outputs
Audio Inputs
Audio Outputs
Radio Tuner
General
12V Trigger x2
IR in x2
6V rSeries PSU x1
5 060133 602521
