Sorry if I caused offence zanash.
I'm really greatful for all the help I've received from the members of this forum, the last thing I wanted to do was to upset anyone.
I've heard the arguments for using decent quality interconnect cable, but this up rated power cable stuff is new to me.
Next time I'm out and about I will take your advice and see if I can aquire a loan power cable from a hi-fi dealer. I think I'll get the Mrs to swap them over randomly and not tell me she has done it and see if I notice any difference.
From an electrical point of view though, the main reason for upgrading power cables for ones with larger conductors is so more current can be safely run down them.
Filtering of signals is usually done using electrical components that have reactive properties (capacitors and inductors). The value of capacitance or inductance is calulated so that unwanted freqencies are removed from the signal. I don't see how a power cable can filter the mains.
But as pointed out by Rusty, I can't knock it until I've tried it, I may very well be back in a couple of weeks totally agreeing with you after I've had a go.
