Anyone compared high end Class D power amps?
Discussion in 'audio' started by Thetiminator, Jan 7, 2020.
  1. Thetiminator
    Thetiminator Painfully virile
    As above, I’m looking for really good Class D power amps. I have a pair of Temple Audio monos at the mo which are so much better than they should be.
    Has anyone any experience comparing the likes of ‘high end’ Class D amps? Bel Canto, Jeff Rowland, NuPrime etc. Etc.
    Thanks.
  2. Purité Audio
    I think I have tried nearly everything Class-D / Class- D hybrids at some time or another, what would you like to know?
    Keith
  3. Alex S
    Alex S carbon based lifeform
    I have the Temple Bantam Gold, the mono blocks (with DC2 & 3 Sean Jacobs PSUs) doing useful things in second and third systems. My main system has the Bantam One (built as a power amp only because that’s what I wanted) and it’s better than the mono blocks whilst looking a lot nicer. So I’d start there.
  4. hifinutt
    hifinutt hifinutt
    yes had bel canto some ref 1000 standard which were ok , then had some coherant modded ref 1000 and these were so much better . a good many years ago now so i can only think they have massively improved . interested in the current generation of mola mola , nord , march audio etc . currently using some modest class d icepower monoblocks with a bel canto pre amp . sounds a lot better than i thought , lovely realism and incredible vfm . not as good as the thrax or the msb but then it cost a fraction of the price . strangely enough these amps are on the warm side , i did think they would be completely neutral and even a bit sterile but been surprised
  5. Thetiminator
    Well I’m looking for something that’s a touch on the warm and fuller sounding rather than that slight thinness you can get with Class D. I’d heard that these NuPrime amps were excellent for the money, I’m done spending big money on power amps after hearing what these little Temple Audios can do for £500....although I am using their upgraded power supplies too...
    Going from £20-£30k power amps to these and having to concentrate to hear the differences just isn’t funny....
    Nytechy and Andrew Williams like this.
  6. simon g
    simon g Older, wiser & retired
    How much do you want to spend?
  7. Thetiminator
    £2-3k at the very most ballpark....I know that doesn’t seem much but prefer 2nd hand/ex dem, so that should open the door to some decent stuff...
  8. Thetiminator
    Oh and something without silly high damping factor ideally...I find those with really high DF’s can over damp the bass...
  9. Purité Audio
    I don’t find them thin, just transparent if you glance at for example any of the NCore based designs over at ASR.
    Which speakers are you going to use them with?
    Keith
  10. Thetiminator
    Big Living Voice horns, they just worked better than all the valve amps I tried...can’t be doing with valves...
    The 15” bass drivers have a lot of damping already so don’t need too much more...
  11. Purité Audio
    Presumably they are a pretty benign load and relatively easy to drive, compression drivers for mid and treble?
    Which 15” drivers are in them?
    Keith
  12. simon g
    I've tried loads of Class D a,ps. Hypex and ICE of different types are ubiquitous. The newest ICE module is pretty good. Many small outfits out there selling modules in a box at reasonable prices
    Jeff Rowland uses Pascal modules I think. I really liked the ones I tried, but they are very pricey for what they are.
    I'd take a look at Primare. The A60 is superb, but the A34.2 is certainly no slouch and much less costly.
    You could also look at Gato, which uses International Rectifiers. I'm currently selling my DIA250s, which is an integrated but is easily used as a power amp only.
    IME, the Primare and Gato win on SQ over the same price point Hypex and ICE based amps.
    Peter McDermott, Robby and TimF like this.
  13. misterdog
    misterdog Not the canine kind
    I went from N-Core to these Class A/B for that reason, near zero distortion but warmer. I'm sure Tom or someone this side would build you a a pair.
    At least six of us on here using this family.
    https://neurochrome.com/products/modulus-686
  14. brumjam
    brumjam pfm Member
    Make that seven. Superb amps.
    hifinutt likes this.
  15. Thetiminator
    Yeh
    Yeh 7.5-15ohms iirc. Bass drivers are Vitavox as are the compression driver mids....105db sensitivity...
  16. Zombie
    Zombie pfm Member
    105 dB? Do you need a power amp?
    Tarzan likes this.
  17. Thetiminator
    Lol yeh. Apparently they only need one watt but needing and sounding best with are two different things. Personally I’ve always loved high power amps driving high sensitivity speakers...
  18. Strictly Stereo
    Look for something using Hypex, ICE or Pascal modules and you won't go too far wrong.
  19. Fretbuzz
    Fretbuzz pfm Member
    Had a Nord NC252 (basic N-Core one). Incredible top-to-bottom transparency, and no harshness, but just wanted a bit more warmth in the end.
    Driving Audio Note speakers.
    Tarzan likes this.
  20. Thetiminator
    Exactly where I am at...
    Tarzan likes this.
