Single ended is where the signal is amplified through a single transistor or valve, the music waveform stays in one piece.
most amplifiers are push pull where the positive and negative parts of the signal ( think in and out of the speaker cone )are split with one device amplifying the positive and the other amplifying the negative. The idea is that both sides match, and the waveform retains its original shape, but alot of things have to be right for that to happen, the advantage is that you can get alot more watts out of a push pull pair,
in push pull there are different classes, a ab b c.. in simple terms its just different spacings of the two halves of the signal wider apart to get more volume.. if you can understand that you will start to understand the quality relationship to different classes of amplifier
Hope that makes sense.
Whoa there! In push pull class A it also "stays in one piece" but with less asymmetry.
Daft analogy time again.... Where's the Ladybird book illustrator when you need them... Imagine lumberjacks, who are OK, the smell of pine.. and heatsinks
Are you sitting comfortably boys and girl? Then I'll begin. (that's showing yer age if you remember that 'on't wireless
A two man large bow saw.
Single ended class A is like one man on his own doing both the pushing and the pulling... with a spring in place of the other bloke.. There's no gap where no ones doing anything but he is probably stronger pulling than pushing and as he gets to the end of his reach... plus the spring is helping in one direction but hindering in the other...
Until the "start sawing call" goes out the spring is holding the saw steadily in the middle against the strength of the bloke on the other end. This work he's continually putting in is the wasted energy, the heat, of class A.
Class B would be two blokes, one on each end, but as it gets
nearly to half way one just lets go.. in both directions... there's a glitch in the movement as one stops pushing and the other starts pulling... or vice versa...
Until the "start sawing call" goes out the bow saw is resting on the plank whilst they have a cuppa. No work is being done, no heat, but they have to run back to the saw, late, and then the movement is strong but jerky.
Class A/B like above but each helps the other one out by continuing to push until it gets a little beyond the half way point and only gradually reducing the push whilst the other takes up the pull.
They stay in post and with a good grip on the saw and a light pressure but only just breaking a sweat.....
Class A push pull they both push in one direction and pull in the other for the full movement of the saw and as one reaches a point where their reach limits the strength they can put into it the other is reaching a point where they can pull at their strongest and this equalises the total into a constant smooth motion twixt saw and wood...
They both pull or push full strength against the other to keep saw still in the middle until "start sawing call" goes out but each is only using half the strength of the bloke working against the spring in the single ended case. Still lots of energy being wasted as heat but rather more efficient than pulling against the spring.
Mismatched output transistors can even be brought in to this as being one geezer goes to the gym more often than the other
