snaphappybob
Hi folks.
I keep getting intermittent buzzes through my system which I'm guessing are entering through the speaker cables. They sound like the noise you used to get just before your mobile phone starts to ring. There is a sequence of four or five short buzzes through the speakers.
System from mains to speakers is Russ Andrews powerblock with mainly RA leads. (all checked and in good order) a mac mini with ifi Zen DAC used as a music server, an Arcam Alpha 5+ cd player, Oppo UDP-203, Naim NAC 82, Teddy Pardo Dual Teddycap (brand new purchased to replace Hicap) Naim NAP250 with Avondale 220 boards, 5 metre NACA5 speaker cable to mk2 Naim SBLs.
I can discount all of the sources as it happens when they're all turned off so I am assuming that the NACA5 is acting like an aerial. One cable is layed over itself rather than coiled but the buzzes come from both speakers anyway.
Any advice as to what the culprit may be?
FYI this has occurred with other speakers and with the Hicap so its not the Teddy or the SBLs.
