How do paypal explain allowing JL to send to a none verified PP address? It's in their Ts and Cs after all. She's right to tell them to do one.
Just to clarify the situation.
Someone has accessed her JL account online, ordered the goods, then managed to send it to another address but you have been notified that the initial delivery address was the account registered one, ie yours.
Was the address change done via her JL account ?
Can she access & view the order online at JL to see where it eventually ended up being delivered & I assume signed for ?
Thanks for clarifying, this sounds sophisticated, also sounds like an inside job at JL or Paypal
More likely someone has captured Elizabeth's paypal password, seen a purchase from JL the day before in her paypal history, seen an opportunity for another repeat JL order and JL may have slack delivery address security hence the different delivery address.
I have a Draytek Vigor 2862 router with all of the settings default more or less and the firewall is definitely switched on.
I'd like to know how her name was changed if it wasn't an inside job.
I asked my daughter about this last night and she said that the name change was only on the delivery details not her PayPal account so that must mean that JL allowed the name change.
I remember the thread.
https://www.pinkfishmedia.net/forum/threads/router-advice-recommendations.214536/
That was in April 2018, have you updated the firmware since buying it ?
In May 2018 Draytek issued this:
https://www.draytek.co.uk/support/security-advisories/kb-advisory-csrf-and-dns-dhcp-web-attacks
It was all over the internet.
https://www.bleepingcomputer.com/news/security/draytek-router-zero-day-under-attack/
https://www.theregister.co.uk/2018/05/21/draytek_routers_security_vulnerability/
https://www.ispreview.co.uk/index.p...es-popular-draytek-broadband-isp-routers.html
I would check which version firmware is in your router as if not updated is vulnerable to a DNS problem and MITM type problem.
If affected updating the firmware wont fix it, settings need correcting after the firmware update.
Post screen grabs if you need any help. You need to check the DNS settings and to check there are no remote users enabled that you don't know of as that is how your IP address is used remotely.
