So I have the cheap and cheerful stock power supply running my Clearaudio Performance DC. A power supply upgrade is on my mind but the stock unit keeps the speed rock solid. As this is the case, can there be any advantage to an upgrade?
Whether a deck be AC or DC driven, it is the subsequent motor control electronics that govern the motor speed and direction of rotation.I am far from an expert but tend to agree. As I said the TT is rock solid spinning 33.3 rpm with stock power supply so I am puzzled as to what a more substantially priced power supply can achieve, other than match the performance of the stock supply at accomplishing the same rpm.
Not sure what TT your using, but the Performance DC is belt driven. I wonder if noise added to the switching supply can via the belt, effect the performance of the platter and if so, would that impact on the rpm?.I was similarly wondering if a linear power supply instead of the 24v wall wart would offer advantages but as the deck works well regardless I guess it’ll be a waste of money. The only issue I have would be the noise added by the switching supply.
Perhaps not to ALWSR standard, but the typical turntable DC motor controller is regulated, else the output voltage vary with the wind. Many employ an LM317 (or similar); in the case of Origin Live's kits they claim stability to be within a hundredth of a volt input* (circa 2.35V @ 33.33RPM for their motor/pulley). Naturally they supply increasingly advanced circuits, 5 options in total, with option 3 and up having 'fully balanced' round transformers (a larger one within options 4 and 5). Balanced is likely to offer a noise performance improvement, however, I'm not so sure that size matters with DC turntable motor supplies, especially so when one is looking to get circa 2.35 to 3.xV out.Run the supply into a superreg (AWSR) set to the correct voltage and leave it at that...job done
Thanks Martin.That circuit LM317 is a little bizarre, esp for use at such low voltages: the resistances are very large , leading to not enough current through the voltage setting chains for the output to be stable - there is also a (variable) 50microamp or so leakage from the ADJ pin , and that alone multiplied up by 50Kohms means about 2.5v minimum output for a start!
It, or something like, could be easily finessed into working - I doubt it'd needs seven adjustable trimpots though
Excuse my ignorance, but what is a superreg (AWSR)?Run the supply into a superreg (AWSR) set to the correct voltage and leave it at that...job done
Er, ALWSR.Excuse my ignorance, but what is a superreg (AWSR)?
