Hi everyone
I am new to the forum and posess little or no electronics knowledge. I am on a mission to upgrade my humble Marantz cd600 ki after I heard the improvements in my friend's cdp of the same model. It was modded by audiocom. I have searched this and one other forum for some guidelines.
So far I have settled on a Clock upgrade + psu from Net-audio which seemed to be of reasonable value...or atleast more so than Trichord and Audiocom.
as to the rest of the mods I am open to suggestions.
But I have a few specific questions regarding the Audiocom upgrade scheme and would be very greatful if those in the know would be kind enough to answer them
Audiocom upgrade scheme:
http://www.1st-4-audio.com/control/news/anmviewer.asp?a=131&z=36111
1.are the "sonic" upgrades possible at a lower cost.?
2.Are there suitable substitutes for the Black Gates?
3.is the proposed scheme for the implementation of the BGs an effective one?
4. are there cheaper substitues for the voltage regulators? I have on the ALW site but gather that they are not sold as completed units. is that correct?
5. I have been trying to find the replacement Schottky diodes advocated by Audiocom in the scheme without luck. what other diodes can one use?
here is a link to the schemetics of the 6000 ose which i believe is the same as the KI
http://www.garmin2.prv.pl/
You will have to select TUNNING -t-> MARANTZ --> CD6000 ose
then click on the word in blue text "tutaj"
A summary of the upgrade scheme
parts no# /6112/13/14/15/16/17/18
Silicon diodes 1N4003 replace with 11DQ10
part no# 2131: Elect. 35V/1000µF rep with BG-FK 35V/2200µF
part no# 2132: Elect. 35V/1000µF --> BG-FK 35V/2200µF
2119: Elect. 16V/4700µF --> BG-STD 16V/4700µF
2122: Elect. 6.3V/3300µF --> BG-NX 6.3V/2200µF
2219 + 2221: Elect. 16V/220µF--> BG-N 16V/100µF
2222 + 2220: Elect. 16V/220µF--> BG-N 16V/100µF
7111: Voltage Regulator 7912--> Super-Reg 7912
7112: Voltage Regulator 7812--> Super-Reg 7812
7113: Voltage Regulator 7805--> Super-Reg 7805
2120: Elect. 25V/47µF--> BG-NX 6.3V/220µF
2327: Elect. 25V/220µF--> BG-NX 6.3V/220µ
2115: Elect. 16V/470µF--> BG-FK 16V/220µF
2116: Elect. 16V/470µF--> BG-FK 16V/220µF
2311: Elect. 16V/470µF--> BG-NX 6.3V/470µF
2312: Elect. 16V/470µF--> BG-NX 6.3V/470µF
2316: Elect. 16V/470µF--> BG-NX 6.3V/470µF
2317: Elect. 16V/470µF--> BG-NX 6.3V/470µF
2323: Elect. 16V/220µF--> BG-N 16V/100µF
2324: Elect. 16V/220µF--> BG-N 16V/100
Regards
Shamsur
Regards
Shamsur
