flashgo
DIY Practitioner
I had some spare Hiquophon tweeters, so I decided to build some mini-monitors. (Not the greatest logic, I know, but such is the mindset of this hobby.) At this point, Ive also acquired some KEF B110 mids and appropriate X-over components and hardware. The plan is to build some Falcon Acoustics clones that are similar to (but better than) KEF Ref 101s. I also have the help of a professional carpenter friend who has experience building speakers. Oh yes, Ive never built speakers before.
I need advice on wood. The Falcons are sealed boxes constructed of 12mm baltic birch. Im told that this wood gives a little so that the boxes effectively absorb the back wave off the mids. (What do I know?) However, the KEF B110 has a mounting flange that takes up most of the thickness of the birch ply, so theres no way theyll be supported on the 12mm front baffle. I've never seen a Falcon, but I have some KEF Ref 101s, and they appear to have a thicker front baffle that accommodates the B110s.
Alternatives were considering:
I love mesquite, but I fear itll affect the sound. My friend can also do a 3mm mesquite veneer over the birch, but will that adversely affect the sound since its a relatively thick veneer?
- use an 18mm thick baltic ply on the front, but that would require buying a huge chunk of wood for $50, only to use a few bits,
- glue an extra 12mm wooden frame behind the B110 flanges, or
- make the cabinets out of solid 18mm local mesquite wood.
