moebiusband
Member
Hi,
I am about to make my beloved Linn Kan II active. I already removed the grill and the driver units (one tweeter plastic ring was broken). Then I wanted to remove the crossover and realized that the crossover is almost one unit with the terminal posts. I am unsure how to proceed. The terminal rods seem to be soldered to the crossover and I do not want to destroy the crossover. I searched the internet for similar terminals but did not find any. I would need 4mm Banana sockets with 8mm rods and more than 25mm long. Another option would be to keep the crossover in the box and solder the new cables from the drivers directly to the terminal rods. But I fear that a part of the crossover is active. There is continuity between +/- of each driver terminal pair. I guess a capacitor in between. Also can you recommend what cable to use for internal wiring inside the speakers? Linn used standard 2.5mm2 flexible hookup wires.
Any help is highly appriciated.
Jan
Jan
