Hi All,
I also posted this in audio section, but maybe better here. I have a Naim CDX2 (first model, no digital output) that a few months ago started with a big diference in volume between the channels. I took it to the shop where I bought it (2nd hand), a well known place for audiphile gear in Lisbon. After a few weeks they told me that they could not diagnose the problem and that the unit had to be sent to Naim UK, with a shipping cost of at least €200 on top of whatever problem Naim would find (maybe). Following the advice of another friend that works in the area, and to avoid the cost and damage risks associated with shipping to the UK, I resorted to another shop here locally Lisbon. They fixed the problem by changing the 2 Burr Brown PCM 1704K. Initially, only 1 was defective, but the other also broke while they were trying to fix the first one so they end up changing both, at a cost of around €300 total.
So now both channels are playing at the same volume, which is great. However, the volume is now much lower than before this intervention. To have the same output levels (perceived, by listening) that I had with the pre-amp (Linn Kolektor) at 50-55% of total volume, I have now to to put the preamp volume at 75-80%. Also, I sense a lot more bass and less highs than before, which I can also try to correct in the Kolektor, but for sure something is still wrong. I opened the unit for inspection and I could see one of the DACs that was substituted and this is a Burr Brown PCM 1704J, not K as the ones that were previously in the unit and that I still have. I could find that J and K are classifications of the dynamic range of the dac with K being better than J, but could that justify should a big difference in volume level ? Is there any way to change the voltage regulation of the PCM 1704J to correct the perceived differences in sound ? Should I send it to Naim UK and ask them to put 2 new Burr Brown PCM 1704K ? Ask Naim UK to install digital out (bypassing the internal DACs - I would have to buy a separate DAC which I do not have at the moment) ?
Any advice is welcome, thanks.
