Hi all,
I'm new here but recently found the forum very helpful in diagnosing an issue with my dad's A&r a60. We got this out of storage a few years ago and have been enjoying it since.
Recently however, the input fuse blew when we turned it on. Replacing the fuse did nothing (it immediately blew when turned on). On reading through posts on this forum, replacing the power transistors was recommended which I did and this initially seemed to solve the problem. I also checked all other components for any degradation or leaking but didn't see anything.
However, now the amp turns on the when the fuse is replaced, works perfectly for the duration of the session and is then turned odd. If I turn it on immediately it turns on and operates fine. If I go back a few days later, it will not turn on and I find the input fuse blown. If I replace the fuse, this process is repeated.
I'm not bad with soldering electronics but my knowledge of the inner workings of an amp is minimal and I'm lost for where to start with this problem. Does this sound like anything anyone else has experienced and if so, can you give me some pointers to solve this problem.
Any help/advice appreciated!
Cheers, M
Cheers, M
