doctorjuggles
Duplicating my post from another site as both places have great input from knowledgeable users. Anyway, it's a little long but please bear with me!
Bit of background - I have an HP Microserver with 32TB of space servering up all my media via Plex over a wired network throughout the flat. While I haven't been keeping up to date on the latest tech in hifi, I'm fairly comfortable learning new stuff, so feel free to go into techy detail if you think it will help. For example I'm happy to run a separate server software for music only if that's going to make things easier - server can handle plenty more stress.
Bedroom Requirements
I'll be moving my stereo system out of my bedroom and into the spare room - looking for a simple, streamlined replacement solution for the bedroom and my thinking is to either get a fully wireless system or, at most, a wired system with a single box that streams everything to attached speakers. Due to space limitations, the speakers have to be (a) very forgiving of placement and (b) not very big.
As it won't be a critical listening system and merely there for enjoyment and convenience, what are my best options?
At the moment I'm considering Sonos or Bluesound but I'm not even sure how it would work. Do I need to have a base to connect wirelessly to the speakers or are they controlled on the phone? If they can be controlled by phone but it's preferable to have the base, why is that? And how does the sound of, say, two Sonos Ones compare to having, the Sonos Amp plus two small bookshelf speakers?
Remember that the point of this system is fun and unobtrusive and above all, easy to use - so while I want good sound, it doesn't need to compete with a proper hifi. In this case, good enough is good enough (but I also don't want it to sound like a pair of Monster Beats!)
Budget isn't set but lets start at £1k and see what answers I get
Computer/Hifi Room Requirements
The stuff moving from the bedroom - I have a Resolution Audio Opus 21 CD player which I love, so that's staying, and the Totem Sttafs are staying too. I'll probably be replacing the Roskan Caspian MkII with something that has better synergy. Now the main question is whether the onboard DAC on the Opus frmo the PC is worth using, or should I be looking at something more recent too, to open up higher res audio? The Opus 21 DAC is 4 Burr Brown PCM1704 @ 32 - 96 kHz / 16 - 24 bit. Would I be better off grabbing something that can do it all (MQA/DSD etc). I have to admit that while I'm comfortable with tech, this is an area I've fallen waaaay behind the eightball on, so happy to be schooled and convinced either way here. I usually tend to err on the side of future-proofing though, so if there's something I should be looking at, I'm all ears (and I usually like the Chord DAC sound if that helps)
Again, budget is moderately flexible, let's say £1k for the amp and £500 for the DAC as a starting point. (These will all be second hand so I think we'll have plenty to play with)
Other questions
For the Computer/Hifi setup I'm also open to a one-box solution with onboard DAC if that's going to work more elegantly. I was eyeing up the Peachtree Nova but thought better of it as it doesn't have the latest Hi Res capabilities, but if there's something else I should consider, feel free to point it out. At the moment I'm considering amps from Sim Audio, Plinius, Ayre and Sugden (whatever falls within the c.£1k range second hand) so would need to compete with that sort of level, but obviously if it has onboard DAC I'd spend more (c.£1.5k) as I'd be saving on the DAC side of things. Experience tells me this is likely to be less of an option than the separates though.
Other questions
