Most solid state amplifier input filters are simple first order, rarely much effect below 50kHz.
Try putting a signal with artifacts around 28kHz into this tweeter
https://www.madisoundspeakerstore.c...rless-da32tx00-08-1.25-corundum-dome-tweeter/
15dB peaking tells you that it is ringing like a bell. The two tone distortion figure would be interesting.
I don't think it's as contradictory as it may seem. As may happen in NOS DACs (IIUC) if you reconstruct the audio at the DAC's output by just creating an output voltage corresponding to each digital sample and holding that voltage constant until the next digital sample (AKA zero-order hold) then the audio signal's frequency response gets shaped by a sinc function. And that does indeed roll off the audio at high frequencies if not corrected by an inverse-sinc filter. That's independent of any issues to do with ultrasonic aliases.I've never heard an NOS DAC but proponents of them often cite a smooth and slightly rolled-off top end as a reason for using them, an observation that appears contrary to the above?!
It depends on the music, a high level sine wave at 1kHz might be better than that, a medium level sine at 10kHz will be far-far worseExcept with all this conceptualising, no one has mentioned the voltage size of this noise. Are we talking 60dB down on the audio?...
That rolloff still allows a fair bit of harmonics / HF energy.
One way to look at the HF 'rolloff' effect of not using a filter is that the 'missing' signal power is being presented instead as components above Nyquist.
The problem then is that following kit may - via nonlinearity - then generate difference products at lower i.e. audible frequencies. I did write a general blurb on this years ago but can't recall if I ever published it! I'll have a dig as it has some pretty diagrams, etc.
I think I may have been unclear. If you do the two elements in the second set of bullets in my post perfectly then that is mathematically equivalent to reconstruction.It is a requirement. Mathematics is not a question of opinion or preference. A reconstruction filter is an essential part of the DAC process. A NOS no-filter DAC just leaves that function to be done (in an uncontrolled manner) by your amp, speakers and ears.
In the real world you cannot do the mathematics perfectly. You can only do it sufficiently. So I was saying that it seems better to look separately at those two elements of reconstruction, not go down the "perfect mathematics" route as Chord tries hard to approach.
Not sure I agree. Reconstruction is totally defined mathematically. What does "not audibly damage the wanted signal" mean in mathematical terms?
In a proper conversion process, you can't do the parts separately. The "perfect mathematics" route is how it has been done for the last 80 years or so, ever since Claude Shannon and Harry Nyquist.
It's really difficult to go into details in this type of forum. But AIUI the perfect reconstruction filter has a sinc impulse response. The Fourier transform of that is a perfect low-pass filter with two elements: complete rejection of signals in the stop-band (the aliases); and completely flat pass-band response (remembering that the FT has both amplitude and phase/time delay).Not sure I agree. Reconstruction is totally defined mathematically. What does "not audibly damage the wanted signal" mean in mathematical terms?
I'm sorry I was not clearer. I didn't say do the elements separately, I said look at them separately (in particular look at what stop-band requirements are needed and what pass-band requirements are needed in the real world). In practical engineering there are always imperfections. If a designer grasps that, the complexity of a mathematically proper sinc filter may not be required to get good enough stop-band (ultrasonic alias) rejection, and a flat enough pass-band (amplitude and time delay).In a proper conversion process, you can't do the parts separately. The "perfect mathematics" route is how it has been done for the last 80 years or so, ever since Claude Shannon and Harry Nyquist.
I will think on that but it does not immediately cause a lightbulb moment. My knowledge of digital audio processing was gained through practical experiment building lab. demonstrator systems and there is probably quite a lot of theory I may have not picked up from just reading the textbooks and literature at the time.Short answer: I'm not sure.
Longer speculation: This might be assessed by considering the reconstruction filter as being a pure 'infinite' (sic) length sinc function convolved/windowed with a cutoff weighting function that is all-zeros beyond a given span. Then calculate the max possible energy fraction this produced compared with a perfect 'infinite' sinc. If that fraction is equivalent to below the dither, then forget it?
Not read the article (yet) though. So made that up.
My original question is based on an assumption that a FIR digital filter however long or short it is and however truncated the coefficients, is characterized by the frequency and phase response, provided the bit depth of the signal path processing (including dither) is appropriate to the signal being filtered. .
