Nye Samuel
Herr Katze
My cable is about 0.5-1m short of my needs....Anyone recommend a good quality extension cable...6.3mm jack and 6.3mm socket?
I've used this place quite a bit but you might prefer to rewire them with a longer lead:
https://www.ebay.co.uk/itm/28183856...d=link&campid=5338728743&toolid=20001&mkevt=1
Incidentally the Neutrik Rean Females are a bit iffy in my experience
I only ordered a 0.75m cable...so should be ok.
Ify in what way?
If that happens, I will report it to Lynx.The connection inside can be a little loose sometimes and only partially made leading to crackles and distortion. The Rean line is a cheaper, Chinese-made product range.
Isn't that the 3.5mm socket? Nye needs a 6.3mm and the Neutrik one is perfect for the job.Incidentally the Neutrik Rean Females are a bit iffy in my experience
