jimmymcfarrell
Just recently purchased a pair of Linn Isobariks - having been playing with active Sara’s and stacks of amps, when some ‘Briks became available within sensible driving distance it was obvious they were going to be mine. They’re late model ‘Briks with external crossovers in the stands (not that I’m using the passive crossovers) and separate pairs of 4mm sockets for bass mid & treble. Then there’s a 4th pair of 4mm sockets, what are these for? Are the pairs of drivers wired separately to their respective input sockets & just paralleled at this point? What I’m getting at is can I use this 4th (I’m guessing, currently unused) pair of input sockets to split one of the pairs of drivers and power them individually? And if so, which pair of drivers would most benefit from being powered separately, woofers mids or tweeters? Instinct tells me it would be the woofers however I keep reading that one should use the best (most powerful?) amplifier available on the tweeters when running Isobariks, which seems totally counter-intuitive and may therefore dictate that as all my amplifiers are the same, it would be the two tweeters that would most benefit from being powered separately.
That being said they sound pretty damn good as is......
