£750 - Speakers that sound like an ES14?
Discussion in 'audio' started by syep2001, May 30, 2012.
  1. syep2001
    syep2001 pfm Member
    Let me explain..
    Have borrowed a pair of es14s lately I'm replacement of my Proac 1SCs
    I really like them and am enjoying better bass and imaging
    What else is there that will give me the thump of the es14 and mids but retain the 1sc top?
    Any ideas?
    £750 ish to spend
  2. syep2001
    syep2001 pfm Member
    System is: CD3.5/Flatcap, LP12, 32.5/Hi-Cap/140
  3. divedeepdog
    divedeepdog pfm Member
    if you like the 14's, why spend more??
  4. Gaius
    I wouldn't say 14s have a thump in the bass at all, in fact they can be a bit light but have a very good tuneful bass, tight and agile. They are superb in the mids.
    The 1SC is also a superb speaker, I have had both.
    The Naim SBL might be the way for you to go.
  5. sq225917
    Buy a pair of 1SC tweeters and fit them, pad them down as required.
  6. pocketkitchen
    pocketkitchen Registered User
    For £750 I think you'll struggle to get anything nearly as good as an ES14. One of the best speakers ever made, in my opinion. If you value the top end of the 1SC the most and want a fuller sound, then a bigger set of Proacs would be the way to go but I can't see you retaining the drive and all round enjoyment that the Epos' can provide.
  7. bob atherton
    bob atherton pfm Member
    I don't know very much about the ES14 aside from hearing them, and very nice they are too.
    IIRC there are different tweeters to the early ones that most find less bright and forward compared to the later 14's. So I guess the early ones would be a good place to start. You should be able to get a pair for under £300. £400 saved into the bargain, though you will need some stands as well.
  8. per flemming
    per flemming Registered User
    maybe upgrade your cd source and/or poweramp, ES14 likes power
  9. linnfomaniac83
    I was going to suggest a good pair of used 14s and save some money, clearly it's the es14 sound you like so it's what you should be buying.
    you will have money left for some very good stands such as partington dreadnoughts!
  10. Jag Audio
    Jag Audio Trade: Jag Audio
    +1
    I was about to say the same, the Epos ES 14's are (in my experience) an excellent speaker even now after being launched approximately 20 years ago. I liked them back in 1991 and traded my Kan's Mk1 in for them which had previously served me well.
    I like them so much that I have 2 pairs boxed and saved for an extra sound room I have planned and had I not been using Audio Note AN/E (the SPE/HE fancy jobby) with valve amps I think the Epos 14's may have been making the excellent sounds they are capable of.
  11. Fox
    Fox The sound of one hoof clopping
    Add a couple of good subs cost in some time integrating the two. If its a thump you need that way you keep the ES14s you clearly like and add some weight only where its needed. A couple of BK's XLS200s will suit that budget.
  12. Harry1212
    Harry1212 pfm Member
    2nd hand tatty mk 1 chipboard single wired ES14s
    like mine
    stuff the ports with old wooly socks & change the tweeter cap with a polypropaline 2.2 uF .
    Next question . . . . .
    Cheers, HBS
  13. Harry1212
    NO !!!!!!!
  14. Harry1212
    one Rel Stadium will do the trick nicely
  15. James Evans
    James Evans Bedroom Bodger
    There's a couple of very cheap pairs of ES14s and stands in the dealer classifieds
  16. Fox
    I really seriously doubt it. The trick is to have a pair of smaller sub to keep bass agile to keep up with the 6.6" driver of the ES14. People always make this mistake with subs, they overkill and buy a big feckoff single sub and complain when the bass isn't integrated properly. 2 x 10" subs under driven will work better in a music context than a single massive one. You want it to pick up and occasionally twhack and still have it channel coherent and not be a constant part of the programme flubbing indistinctly in the lower regions everywhere.
    I'd probably look at a cap change after all these years first, also...
    samz likes this.
  17. bob atherton
    I'm with you on this one fox. I used to have a REL Stentor and it was just so so. I now use a 10" BK 200 and it's nigh on perfect with my IBL's. I'll saddle up my pony and be out of here...
  18. jaz9706
    jaz9706 pfm Member
    Try some ruark equinox's , decent pair can be had for £500 ish . You do t like em , sell em on.
  19. YNWOAN
    YNWOAN 100% Analogue
    I used a Rel Stadium very successfully with ES14’s for many years. In fact, my own experience of small subs is that they don’t work that well.
    Eventually I moved on from my beloved ES14s to Yamaha NS-1000Ms. However, if buying new, there is nothing in the region of £700 to compare to them (not a great deal second hand either).
    As for changing the capacitor, well there is only one (only one component in the whole crossover in fact) and it is easy enough to replace with a polypropylene one.
  20. JezmondTutu
    JezmondTutu pfm Member
    Ruark Talismans as an alternative but ES14’s can sound quite exceptional- why I have a pair in the loft!
