£350 auto ultrasonic record cleaner?
One disc at a time, have to drain after every disc and 5 mins to blow (not vacuum) dry?
Not exactly efficient is it?
Looks great. I think there's a market for a well made <£400 ultrasonic cleaner, for sure. I know you can get home brew versions, but they all look too hands-on for the average punter
Saw this elsewhere, he’s trying to raise £130,000 before the end of the year and he’s miles off that, I think last I checked it was at £16,000.
Doomed to failure, you pays your money and take your chances
Who knew this place could be such a tough crowd?
You're more than welcome to search for one that suits you.
I’ve been using a Velvet Vortex for the past few months, on extended (due to the bloody virus) loan from a friend. It can clean 3 discs at once, and by the time you’ve drained the other machine and let it blow dry the single disc it can handle, the 3 records you’ve cleaned in the Vortex then put in a dish rack (maybe with a household fan blowing at them to speed matters up, but not really necessary) are dry and you have another 3 records already cleaned and ready to dry.
The Kickstarter machine a stylish thing, but not the faff free solution it’s being touted as. It’s an illusion of convenience.
Disclaimer, for transparency, I do know the guy who sells the Velvet Vortex as he’s a member of various Audio forums that I also belong to, including here I think, but it wasn’t him that lent me the machine, and I’m not a customer of his.
They're at £78k at the mo, so they might make it. Best of luck to 'em I say.
40khz will be a $100 off the shelf chinese OEM unit for cleaning car parts & jewellery in a nice box for cleaning vinyls
Degritter 120khz ground up new design for cleaning records
It's the type of cleaner that you use as and when , Just drop in your vinyl , switch it on and go do something else , Its not a machine you stand and wait for strumming your fingers on the table
I wish him / them well with the venture
Any method that leaves cleaning solution of the record to dry is a worse than useless design. Clean the record and then leave dirty water on it to dry and leave behind anything washed off the record.
Mad idea.
Mad idea.
Err ! now you have me confused ? o_O
Simple - the wet record is either left to air-dry of dried using a fan. OK if there is a DI rinse after cleaning, but otherwise totally daft.
The great majority of cleaners use suction to remove as much cleaning solution as possible - far saner idea.
won't most of it be left in the solution? with the turntable-type cleaners, the vac is the only option because 100% of the fluid/dirt is left on the record
Ye but Ye but , Whats the difference between air drying in a rack or slightly faster drying using a fan ? I understand the vacuum machines remove water / Cleaner solution but they do not dry the surface 100% either . I use my PRC 4 and put the LP's in a rack to fully air dry
Your choice, it would not be mine.
Would you wash your clothes ( Yes I do ) , drag them from the washing water and hang to dry? ( No I take them out put them in a laundry basket and hang them on the washing line to dry in the garden , Have done for decades , Works for me ) I wouldn't - same principle.
Even my mother, who used a dolly-tub, dolly and washboard for the majority of her life, rinsed things before drying, so do all clothes washing machines.
In the video they say " Fill the tank from the tap " so they use tap water not chemical cleaning fluid
