linnfomaniac83
I bet you can’t wheelie a unicycle!
If it works then it's all good. ISTR that the problem with the Nait 5 was with the control logic, not the pot itself, I've seen them stuck in mute with the front panel buttons flashing. I wasn't aware that they couldn't be fixed though.If I remember correctly, the 5i has a passive preamp design. So it's basically just a pot and input selector in front of a power amp. Certainly easier to replace those parts!
I do have a soft spot for the Nait 3/3R, basically a Nac92/Nap90 in a single chassis, great little amp.
