Martin Colloms
HIFICRITIC
Hi , fascinated by the speed discussion...
3kHz , the peak aural sensitivity frequency for flutter, FM modulation of pitch.
Should be as clean as possible but the measurement is usually psychoacoustically weighted by pulse shape and frequency filtered factors. see Wiki on wow and flutter.
I have published some of this material in Vol 3 no 3 HIFICRITIC in trying to chase down how the the Radiakal motor alters/improves the residual noise spectrum from the LINN LP12. That noise may contains many components some amplified, even misrepresented by the connected mechanical structure.
There will in any case be some of: induced electrical noise, RF , electrical hum components, 50Hz , often 100Hz second harmonic dominant, plus many higher harmonics, the chassis resonances in the 4Hz region, the arm-cartridge resonance. Then come eccentricities for the drive pulley, the platter, and the disc, which may also have warp wow components , never mind thickness, diameter variations for the belt or idler pulley. And finally the contributions from the motor itself , bearings, cogging , rotor balancing, electrical frame vibration. All grist to the mill . Martin C
