Steve Jobs stereo system 1982
Discussion in 'audio' started by tomek, Oct 9, 2011.
  1. rubaiyat_23
    rubaiyat_23 pfm Member
    I can't confirm this, but I suspect that this system was purchased from The Audible Difference, which seemed to be a popular shop amongst the Silicon Valley elite (after various ownership changes, I believe it's now called Future Sound).
  2. tomek
    tomek pfm Member
    Speakers are 100% Acoustat 3s as mentionned by John.
    Gyrodec ? I don't know. Gyrodec has a diiferent platter with some weight under it. But maybe some early Gyrodec have different platter.
    Maby this one ?
    Than as mentionned by louballoo Threshold FET One.
    On the Threshold there is one tuner, and it could be anything.
  3. Mignun
    Mignun pfm Member
    The Gyrodec was reviewed in HFNRR by Martin Colloms in 1982, so could well be the turntable in the picture. It does look very like an early Gyrodec and not like the contemporary Oracle or Win Labs.
    Well spotted on the Threshold. Now, apart from the "tuner", what power amp is he using? :)
  4. tomek
    tomek pfm Member
    No power amp is needed. Acoustat 3 are active :)
  5. louballoo
    louballoo Banned
    I think we are close with this Sequerra Model 1 FM Tuner. It was the very hi end one would expect to match the rest of the kit.
    Louballoo
  6. John
    John pfm Member
    I don't believe they were active.
  7. tomek
    tomek pfm Member
    You are right :)
    They needed power, but there was not amplifier inside, only some transformer to create high tension for the electrostatic panel. Like Quad ESL.
    We don't see the power amp on the picture, it is probably hidden behind Steve. On the Sterephile forum the seller of the system said that it was with Threshold electronics, so it was most probably Threshold power amp.
    Tuner - i don't think it is Sequerra. Sequerra is >20cm high and the tuner which is on the preamp is probably only ~10cm high.
  8. louballoo
    louballoo Banned
  9. tomek
    tomek pfm Member
    Jobs tuner has two green vu-meters on the left side, it is not Tandberg ...
  10. hifi_dave
    hifi_dave Hi-Fi Retailer
    Pretty certain the turntable is an early Gyro - you can just make out the cover and the chassis is very clear. I had the first one here in 1981 (IIRC), John made it in response to the Oracle I'd just taken delivery of.
    Th pre looks very much like a black Threshold and the tuner could be a Magnum Dynalab ???
  11. louballoo
    louballoo Banned
    I doubt the tuner is a Magnum Dynalab, I own the first model the FT 101. I bought it in 88.
    I wonder if the lighting could have skewed the colors? Maybe one of our resident photogs could comment on that.
    Louballoo
  12. engjoo
    engjoo Member
    Those are his rear surround.
  13. louballoo
    louballoo Banned
  14. louballoo
    louballoo Banned
  15. louballoo
    louballoo Banned
  16. tomek
    tomek pfm Member
    It looks like Acoustat 3s was active with a built in tube power amp :) and probably this version had Steve Jobs :)
    Now only the tuner is left ...
  17. Tony L
    Tony L Administrator
    I agree, it's definitely an early metal platter Gyro, the reflection off the lid onto the wall is another clue and indicates the rather large size of the perspex case.
  18. andyoz
    andyoz pfm Member
    Is that unit is sitting on speakers, looks like speaker grill cloth to me - fi so, can anyone tell what they are - they look BIG and American!
  19. darrylfunk
    darrylfunk Banned
    i am sure on an american forum a good few years ago the deck was found to be a gyro with an infinity black widow arm and i recall vaguley some wood bodied cart poss grado or briar.
    i think a few people said the pre amp was the very first spectral or the klyne and that speakers had there own amps.
    i can't find the discussion though....i'm not 100% sure apart from the deck combo.
  20. sonddek
    sonddek pfm Member
    The lamp was probably tungsten balance, and the colour cast is quite strong red-yellow, so the film was probably daylight film, and the VU meters therefore probably aren't that far from reality. If tungsten film were used, and the lamp is more yellow than normal tungsten bulbs due to a coloured filter, then you would expect the VU meters to come up much more blue than expected. In that case they would have been much less blue than they are in the picture, i.e. originally orange/red coloured. I don't think that's very likely though, so greenish is a good guess.
