JimmyB
The current motor on my old kit turntable has started audibly 'cogging' so thinking I'd like to change it for something a bit quieter! It's mounted directly to the suspension so need to keep vibration etc. to a minimum.
Could probably fit a Premotec which will run from the current DIY Armageddon but are the new Rega 24V motors or any of the Pro-ject motors quieter with less vibration?
Would also try DC but kits seem overpriced for what you get (e.g. basic control circuitry).
Any experience out there of what the current best option may be?
