I've recently noticed there is a mechanical hum from the motor of my Rega RP1 turntable. I'm not sure if this just happened or been this way since new. Only found out when playing with the lid down, normally used without lid.
From my Internet research, lots of discussions seem to be centred on electrical hum but I've determined it is mechanical. If the lid is down, it can be heard about a foot away but without lid you need to listen right beside it and at eye level with the turntable.
I wonder if this is normal or should I get a replacement motor.
I've recently noticed there is a mechanical hum from the motor of my Rega RP1 turntable. I'm sure if this just happened or been this way since new. Only found out when playing with the lid down, normally used without lid.
Sorry i've just found this thread so a little late throwing in my 2cents !
Yes Rega do shift a lot of decks and its inevitable a few rogues get thru. I got a new RP3 from Dave and soon had to return it in Dec2014 for a motor swap (noise) and prior to that the arm had wiring issues and that was swapped too (audible 'crackle noise') - both fixes by Dave were FOC. Can't fault the service at all.
So, some time further on and the motor has slowly deteriorated and is again audible with the lid up and noisy with it down. I also had speed issues and a few belt swaps later its sounding OK and is more stable.
Whether Rega are fitting newer, quieter motors now I couldn't say but if they are then I'd be interested in a swap. Plus, if the Neo TTPSU helps reduce noise and stabilizes speed then that would be interesting to know too
regards, richard
Thanks Linnfo - that's really useful to hear. I've not seen any feedback on the Neo but that sounds like a decent upgrade. Wonder what others will say - especially Mr Darwin! However it's Interesting that it allows fine speed adjustments too. Regards RichardMy experience of the Neo is on a P5 with an already quiet motor, I’m not sure whether the motor itself is quieter as it’s mounted with Allen bolts and has bushings on a P5 being a higher tier deck... however it brings very notable improvements is sound. Surface noise is lower, pitch is more stable, detail and dynamics are improved and the bass seems tighter/faster.
