Rega red silicone belt
Discussion in 'audio' started by Weirdness, Aug 11, 2013.
  1. Weirdness
    Weirdness pfm Member
    Hi all!
    Did a quick search and couldn't find anything other than mention of the RP40--wondering if these belts are going to be available for all tables, when and how much.
    Have had the white belts on my p9 for a couple of years so I'm probably due, may as well try the red belts if they are going to be available soon.
    Side note--bought my original series p9 as new old stock do I need to do an oil change on it? Do myself or bring to a tech?
    Thanks...
  2. DSJR
    DSJR Between us and them
    The oil on Regas generally lasts for a decade or more before it dries out or at least congeals a bit into a dark brown goo. The P9 bearing may well be different though. As for belts, why not either PM Paul Darwin here (if he misses this post) or give Rega a call in the morning :)
  3. Hi Five
    Hi Five pfm Member
    Try some Edwards Audio Little Belters they are awesome.
  4. DSJR
    The Edwards belts add motor noise as they're very tight (according to a recent review AND a friend's experience with one). The P9 ain't some beat up old Planar from yonks ago that you can bodge away at with any old 'me too' rubbish, but was very carefully conceived from the outset. T'would be a shame to ruin it with some third party stuff intended for a bodge-up RP1.. Apologies, I don't mean to be rude, but these things need to be said IMO.
  5. Robert M
    Robert M pfm Member
    My white belt has a kink of some sort in it, maybe its because I haven't use the rega p2 much in the last year.
  6. paul darwin
    paul darwin Trade: Rega Research
    Hi Rob, if you pass the belt a few times through your fingers and "warm it up" the rubber compound will asume its normal shape.
    Paul Darwin
    Rega Research
  7. Robert M
    Robert M pfm Member
    Cheers Paul, will try that.
    Any info on the red belts?? :)
  8. paul darwin
    The red silicone belt has been developed for use on the Naiad turntable project and will also be the belt in the RP3 40th anniversary package. I have yet to see one in the flesh myself but would expect that they would be made available as an upgrade in the future as with the white belt.
    Paul Darwin
    Rega Research
  9. Rack Kit
    Rack Kit pfm Member
    I heard that the original colour of the belt was meant to be Green but they weren't allowed to build on it.
    Sorry, couldn't resist. ;)
  10. Weirdness
    Will keep an eye out thanks.
    Maybe I'll just skip the belt upgrade and go straight to the RP10...
  11. thebiglebowski
    thebiglebowski pfm Member
    I've seen the white belts for sale on the analogue seduction site, do they make a difference and if so why?
    Is it worth adding to my rp6?
  12. antonio1
    antonio1 pfm Member
    any news?
  13. Daniel Quinn
    Daniel Quinn Banned
    This post is out of order .
    You are entitled to your opinion on the belt per se , though for ****s sake its heresay evidence .However , you are not entitled to your sycophancy for all things rega leading to the rubbishing of all after market add ons ,to be simply accepted without rebuttal.
    It is inappropriate and crass to call none manufacturer add ons "bodges" or me to rubbish ,especially as there is an established culture of none manufactured upgrades to most if not all turntables .
    This is hifi suck it and see .
    Also your post is glaringly incongruous when juxtaposed against the fact that Mr Darwin admits a better belt will be available as an after market add on shortly for all rega turntables which will include the rp9.
  14. thebiglebowski
    Do you have word of the day toilet paper where you just pick a random word and throw it into a sentence?
  15. Daniel Quinn
    Daniel Quinn Banned
    I would bet £10 that every word in the post above as been used in a previous post .:p
  16. tee-bee
    tee-bee pfm Member
    I've got the Edwards Audio blue belt.
    Much better than the OEM Rega black belt. No issues with noise.. then again I own an Rp-6.
  17. linnfomaniac83
    Does it maintain the correct speed? I have known third party belts to make the deck run fast!
  18. tee-bee
    tee-bee pfm Member
    No issues at all.. am happy with it. Don't think I'll go back to the black Rega belt
  19. Sue Pertwee-Tyr
    Sue Pertwee-Tyr pfm Member
    Curious as to how that could happen. Surely turntable speed is a function only of motor speed and the ratio of the diameters of the motor and platter pulleys. Belt tension, or any other property of the belt (apart, possibly from a lack of friction), shouldn't affect any of these, should it?
    I'm just wondering if this is a generally accepted phenomenon, and if so, what the explanation is because, on the face of it, it's no more likely than mains cables making a difference, and we know what short shrift they get, on here.
  20. YNWOAN
    YNWOAN 100% Analogue
    I'm afraid that is an oversimplification and belt tension does definitely alter speed - easily checked with an accurate strobe.
