Alan roche
Member
Hi, my first post
I have a Rega 3, done the following
1: rewired tone arm the s shaped one by vinyl source
2: cleaned and relubed the platter bearing
3: replaced belt and motor support band
4: replaced the capacitor
5: lubed motor shaft
Question is, the deck is very slow to start in 33rpm mode and wont start in 45 rpm mode even without a record or mat on the glass platter, unless you manually get it going, then its running at 31rpm and 41rpm once it gets going
Does the 24v upgrade have more torque than the original?
Many thanks
Alan
Many thanks
Alan
