Problem with Audiolab 8200CD
Discussion in 'audio' started by Brian_, May 7, 2012.
  1. Brian_
    Brian_ New Member
    I have just bought a new 8200CD and it is playing up. When I unplug the USB from the computer I get hissing white noise in both channels and the signal is completely distorted. It resets ok with a power off but randomly comes back. Sometimes it happens when I flick a mains switch on. I was wondering if it is my mains causing the problem but I'm not sure what to do about it. I'm using it with a Roksan Kandy K2.
    Has anybody else had this issue? I'd be very grateful for any input. I bought mail order so I thought I'd try resolving myself before going through the hassle of returning.
  2. Lyricman
    Lyricman Active Member
    I had exactly the same problem and after speaking to Tech Support they arranged for my dealer to swap it out immediately. Mine was the CDQ but sounds like the same problem.
    New one was perfect, it is a fabulous player.
  3. Brian_
    Brian_ New Member
    Thanks for replying. Good to hear of someone else with the same problem; I'll follow your lead.
    I agree about the quality. I've never heard anything as good, when it's working.
